As the title suggests, WiFi just stops working if I haven't touched the machine for a while. Hard to say how long exactly, an hour, maybe two. The USB WiFi device still has its light on, but it simply no longer functions. This is most likely a linux issue rather than a pathpilot one, but I'm doing everything with Tormach supplied goods and no modification as of now, so I don't want to start messing around with the OS right away. I did find this, however, for those interested
wireless - Wifi stop working after while on Ubuntu 14.04.2 - Ask Ubuntu which seems to describe the same issue.
Unplugging the USB WiFi and replugging it gets it to work again, however, I have to do some acrobatics to get to the thing.
Also, I get no audible confirmation when I change axes on my pendant, whereas I used to on my Mach3 setup.
And lastly, I cannot get Pathpilot to advance in GCode that doesn't have spindle motion. This is only a minor inconvenience when running my companion spindle - I just set the main spindle to 250 RPM - but if I wanted to do something where I specifically wanted the main spindle stationary, is there a way to fix that?
