I have the USB WiFi from Tormach and it worked for me, but not consistently, so I just hard wired the ethernet connection. I've seen instances with other things where the wifi router would make a difference. Do you have another wifi router you can try as a test? How about making your phone a wifi hotspot? Those may not be permanent solutions, but if it works, it points to an issue between the WiFi USB and router.
