I've been really happy with Milfast E stop kit.
Anyone rig up a remote cycle start button for pathpilot.
I had a bit of a production type job and hated grabbing the mouse with chips and coolant on my hands.
I contacted Tormach if they made a usb button and they said they don't recommend it.
I should have made a holder for the mouse and a lever to tap the button.
Dave
Tormach PCNC 1100 Series 3 w/ Rapid Turn, Fusion 360
Awall - The Body Armor Dude
CoolCNCStuff_ on Instagram - CoolCNCStuff.com
I built a little box something like the Millfast unit. It is mounted beside the door on my enclosure. Three buttons -- Cycle Start, Pause, Reset -- andt uses an Arduino Leonardo to generate the required keyboard shortcut keystrokes. I already have a remote eStop from Tormach so it seems silly to duplicate it. Total cost for parts is less than $50.
Would an old USB Pokeys55 which is an USB keyboard emulator work with pathpilot?
You can program each pin as a keyboard shortcut.
Jeff
Probably. All that you need is to generate the shortcut keys for Cycle Start (alt-R), coolant on (alt-F), etc.
Thanks for the info. I'll probably try the Arduino Leonardo box.
This was probably the only production type job I will do though.
Dave
I have no knowledge of the creator nor how well it works but the unit at EntirelyCrimson has a nice looking package.
