Hi Mike,
I want to cut the diamond steel (look into attached the pohot of diamond steel)by torchmate plasma cutter,but I don't know how to operate the cutter .
thank you for quickly reply.
reed
Typically expanded sheet is cut in Manual AVHC mode, with the travel speed being a bit slower then usual, and the plasma cutter set into expanded metal cutting mode.
In the expanded metal mode on the plasma cutter, it will maintain a pilot arc when it loses contact with the material, until it senses the material again and then initiate a cutting arc.
Since the torch is going on and off, the AVHC must be set into manual operation to keep a consistent height. This means that the material must remain relatively flat in order for the torch head not to catch the material. This is usually accomplished by either weighting the material near the cut lines, or somehow strapping the material to the slats themselves.
-Mike
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
