Results 1 to 3 of 3
Thread: I need to fine tune my tm2
    May 2009
    Hello All,
    My Machine is cutting consistantly too big on a male toolpath and, inversly, too small on the female. On a 37" piece it gained nearly an 1/8". Mechanically the machine is sound and the motor ratios are spot on. So what is the best way to adust within the software for accuracy? I am using TM CAD 7.1 and TM3 driver.
    Thanks,
    Dave
    Jan 2007
    Dave,
    The setting you need to adjust is basically your Kerf Compensation. This is controlled in the Torchmate CAD software in your toolpathing parameters. On the basic cut tab, there is a tool selection. In this tool library you can add or update existing tools with different Kerf widths. Kerf is the amount of material your torch is removing, and varies with speed, height, material thickness, and amperage. Typically to measure this you would cut a straight line with all of the settings mentioned set, and then take a pair of calipers and measure the kerf width of the cut. You can then define this width in your tool library and assign the correct tool.
    -Mike
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Dec 2008
    Also before you begin to cut, check to make sure that tool compensation is set to "none". Since the Torchmate CAD is already setting the offset for you, you don't want to add a positive tool compenstaion to it again. This would make your part too large.
  1. Newbie- Can't Tune the Motors??
    By CurtisBarclay in forum Mach Mill
    Last Post: 04-12-2009, 07:48 PM
  2. But what Tune can your router Play?
    By Al_The_Man in forum Stepper Motors and Drives
    Last Post: 04-11-2009, 01:17 PM
  3. Torchmate 1 up and runing, fine tune issues
    By gfelippo in forum Torchmate
    Last Post: 07-20-2008, 03:48 PM
  4. How to fine tune motion?
    By Lasershop in forum Bridgeport and Hardinge Mills
    Last Post: 04-13-2007, 03:00 PM
  5. X2 Tune up?
    By Micro Rotors in forum Benchtop Machines
    Last Post: 02-16-2007, 06:00 AM
