Results 1 to 8 of 8
Thread: TM 1 Gantry Retrofit almost complete.
    Nov 2007
    Thumbs up TM 1 Gantry Retrofit almost complete.
    Well, last week I recieved the precision linear rail and two 25MM Hiwin blocks, and new pc. of 3030 aluminum for the new Gantry remodel. I had already cut the new 3/16" brackets for the remodel out on the table previously. So over the last couple of days I have fabbed everything up and test assembled it to see how it all moved. So far so good. Took it all apart and painted it last night, and then another coat this morning. I should have it all together and adjusted by tomorrow night if something doesn't come up. Here are a few picts for you to check out, and maybe give someone else with a TM1 some ideas on how to make it even better. Let me know what you think.
    When It's all complete with end caps and such I will post some final pictures.
    Attached Thumbnails Attached Thumbnails TM 1 Gantry Retrofit almost complete.-old_style_gantry_1024x768.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_retrofit_047_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_retrofit_045_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_retrofit_007_%5B1024x768%5D.jpg
    TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_retrofit_012_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_retrofit_004_%5B1024x768%5D.jpg
    Registered millman52's Avatar
    Jan 2006
    USA , West Virginia
    Nice job You'll be amazed how much better your cut faces will be after your upgrade. I wouldn't be surprised if you can't pick up some speed too.
    If it works.....Don't fix it!
    Nov 2007
    TM1 Gantry now Complete.
    I finished painting things, and doing all of the adjustments today and ran everything up and down the table 10'. Burned a few parts with it and what a difference. It is now a really competent machine. No wobble at all and it traverses every direction really smooth and deliberate. With the water table there is no dust what so ever, just a little water spray from the 75 lbs. of air pressure I am running at most all settings, so I don't see dust as a problem for the linear rail. I do have the dust caps if I feel I need them though. I am a Happy Camper now. Can't wait to get a real job on it and see how it will deliver. It has been a really fun project with a lot of help and info from this forum. Thanks,
    Shapenfab
    in Washington State
    Attached Thumbnails Attached Thumbnails TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_finished_001_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_finished_006_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_finished_008_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_finished_009_%5B1024x768%5D.jpg
    TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_finished_011_%5B1024x768%5D.jpg   TM 1 Gantry Retrofit almost complete.-plasma_table_gantry_finished_016_%5B1024x768%5D.jpg
    Jan 2006
    USA , West Virginia
    Glad you are up and running. You have done a really great job on the upgrade. I'd plug those rail holes especially if I already had the caps.
    My table has been very addictive to run. I used to hate to cut parts on my old pantograph. Now I find myself cutting stock parts way ahead just to get to run it.
    I still use the old pantograph for beveling of many 1" items I need to get 100% weld in the joints. I thought about retireing it completely & just use my track torch for the beveling but I would still need a table the same size for that.
    Jan 2006
    USA , West Virginia
    Blake,
    Take a look at the attached picture. Are your new Hiwin Bearings exposed on the underside like this IKO?
    These cartriges have wipers on them on the ends & top just none under. This allows contamination to get to the balls & groove in rail. I'm quite sure this is why my rail failed.
    Neil
    Attached Thumbnails Attached Thumbnails TM 1 Gantry Retrofit almost complete.-lin_rail_004.jpg
    mls
    mls is offline
    Mar 2008
    nice job looks great
    I am looking to build one of these tm1 machines once everything it working and adjusted how accurite is the table for cutting a circle will it be round etc. Thankyou Mike
    May 2010
    nice upgrade, im building an TM1 w/ a few changes ive come up with along the way also. love the green dye
    Mar 2010
    not green dye it's plasma quench there is no rust in water table
    get it at chemicalmethods.com
    1. Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540
      By GreenLead in forum Benchtop Machines
      Last Post: 11-27-2008, 12:55 AM
    2. Boss Retrofit - best source for complete control cabinet?
      By Scott Kelley in forum Bridgeport and Hardinge Mills
      Last Post: 08-09-2008, 09:06 AM
    3. Need Help!- camsoft retrofit to a anilam crusader retrofit
      By bowlingmac in forum CamSoft Products
      Last Post: 07-24-2008, 10:00 PM
    4. looking for 5 axis Simultaneous complete retrofit kit
      By racefast in forum Want To Buy...Need help!
      Last Post: 03-14-2008, 10:39 AM
    5. Lathemaster/Industrial Hobbies CNC Retrofit Complete!
      By MetDetect in forum General Metal Working Machines
      Last Post: 10-02-2004, 12:29 PM
