Results 1 to 4 of 4
Thread: Extreme cold
    Apr 2008
    Extreme cold
    I think I allready know the answer to this question but would still like to hear some answers. Will extreme cold temperatures cause accuracy problems with a torchmate 2 machine?? I live in Ontario where it's sub zero temperatures now and unfortunately I have an unheated shop. Was trying to do a little work on the weekend and was having some major accuracey problems,,figured it was due to the cold. Just curious if I am right.
    Sep 2007
    I live in north Tx and when I use Hot roll in the winter time I have a real rough time
    the thicker the steel the worst it gets some times the the lead in and the lead out will be off 1/8 to 1/4
    jd
    Mar 2007
    You might want to slowdown the stepper motors. When the motors are slowed down the torque increases. I'm thinking that the cold is causing more friction because of the lubrication getting thicker. Yes the machine will be slower....but you might be able to get the work done.
    I've found that if I use rapid federate as opposed to just federate to go to a point the head may be out of position. This is a problem with using stepper motors without position feedback. If something stops them the computer doesn't have a clue and the head will be out of position.
    Here is a link to their site: http://www.torchmate.com/assistance/...te_Ramping.pdf
    Dan
    Dec 2006
    If you have any moisture in the air it will cause restriction in air flow or freeze all together.Proper air delivery is very important to the cut quality.
  1. Need Help!- I need EXTREME help with 540 and Eletronics! Please!!!!!!
    By SpeedsCustom in forum Gecko Drives
    Last Post: 01-19-2009, 07:47 PM
  2. How cold is to cold for BP Series I CNC
    By jho5820705 in forum Bridgeport and Hardinge Mills
    Last Post: 12-20-2006, 08:13 PM
  3. Extreme Vibration with FNC
    By 1ctoolfool in forum Haas Mills
    Last Post: 12-04-2006, 10:37 PM
  4. Extreme Newbie, please be gentle
    By imagineer in forum General Electronics Discussion
    Last Post: 12-04-2006, 04:07 PM
  5. extreme axis limit
    By bghowland in forum Bridgeport and Hardinge Mills
    Last Post: 09-18-2006, 08:05 PM
