That particular table design is a very clean integrated water table configuration, using angle iron to support the rails, rather then 3x3 tubing sitting on top of the feet. The only potential problem I see is that if weight happened to land on the outer edges of the rails, it could bend the angle iron downward, which will effect how the gantry rides along the rails.
LinkBack URL
About LinkBacks
