Results 1 to 8 of 8
Thread: torchmate cad deleting image to leave path
    Aug 2007
    UK
    Hi
    When I delete the original image I get a message that it will lost the relationship. if I say OK then the cut path cannot be show again I think it has been deleted too. I have followed the instuction by turning off "show cut path" so only the original image shows but what ever I do it wont work.
    Info please
    Tack1000
    Feb 2008
    Not sure about your problem, but was wondering if you like the software, was thinking of purchasing a copy.. Is it as good as it looks. Thanks
    Aug 2007
    UK
    Hi
    I will let you know once have run a few jobs. t the moment program the plasma by hand.
    As far as the first question....sorted it. The "link to original " check box was ticked.
    Thanks any way.
    Feb 2008
    Tack1000 what type of a table you have! Thks
    Aug 2007
    UK
    Hi
    8 X 4 table with water bed, made the lot myself with torchmate auto head adjuster, motors and racks, all the rest home grown.
    Tack1000
    May 2008
    united states
    do you go back and select the view tool path only afterward?
    baker
    Aug 2007
    UK
    Hi
    Yes I did but I found the problem to be the group command was checked so when I deleted the original the whole thing was deleted as they were grouped.
    Thanks for asking
    Tack1000
    Jan 2007
    In the Torchmate CAD Version 7, under the Options menu, select Torchmate Setup, and then select Tool Path Preferences. There is an option that says "Group Tool Paths with Originals" that is checked. If you un-check that, the toolpath and original will no longer get grouped together when you create the toolpath.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    1. Need Help!- Programming Mills To Leave Stock On When Profiling?
      By Eddie1962 in forum Haas Mills
      Last Post: 04-15-2008, 02:30 PM
    2. deleting line between points
      By BrassBuilder in forum Dolphin CADCAM
      Last Post: 03-03-2008, 08:54 PM
    3. deleting post
      By cabnet636 in forum Forum Questions or Problems
      Last Post: 01-15-2008, 06:17 PM
    4. Leave the the Zone to search GOOGLE
      By widgitmaster in forum Polls
      Last Post: 07-23-2006, 03:33 PM
