Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 05-27-2008, 10:45 PM
bakerj99 is on a distinguished road
hey Mr. Mike problem solver
new to the site and have been reading post and noticed that your the man with the problem solving skills so here we go
when i cut out a circle or an oval about the last 20-25% of the cut my machine starts to try to get ahead of itself. it dosent matter how fast i go or the size of the object. this just gives me a little bit of extra clean up and alot of fustration
anything would be helpful
baker
Old 05-28-2008, 11:14 AM
Mike@Torchmate is on a distinguished road
When you mean get ahead of itself, are you referring to the machine moving faster then the plasma cutter is able to cut through the material? What changes during this last 25% of the cut, is the height changing at all or is the speed changing? Does it happen during straight line cuts, or straight lines mixed with arc movements?
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Old 05-28-2008, 03:19 PM
it only happens in circles and ovals and nothing changes height wise the arm just jerky a little bit and the arc dosen't cut through the material
Old 05-28-2008, 04:16 PM
What material are you cutting, what thickness is it, what speed are you cutting it at, and what is your amperage setting on the plasma cutter?
Old 05-28-2008, 05:04 PM
Med-Pac is on a distinguished road
might be a loose ground connection.
Old 05-28-2008, 07:05 PM
the ground is ok i clamp it to every piece instead of having it bolted to the table so i cam rule that out
the material is 3/16 mild steel @ 18 or 15 ipm and 35 amps
could it be something in the way that i'm programing it in the CAD and maybe it doesnt have enough nodes?
i mean i can see the gantry moove out of time when it happens so i am baffeled
thanks
baker
Old 05-29-2008, 09:42 AM
What kind of software are you using to generate the toolpath? What kind of consumables do you use? The 35 amps sounds like an odd consumable.
Our hypertherm 1000 uses 25, 40 and 60 amp consumables. Our voltage control is set around 100-105 for the 25 amp, 155-165 for the 40 and 160-180 for the 60 set-up.
By the way, we have a 4 x 8 torchmate system. Thought I'd throw you a few ideas, but the guys over a torchmate definately know their stuff. i've never had a prob they haven't been able to solve for us. Give em a day or 2, I'm sure they can solve this one for you. No pressure Mike......
Very strange that it will cut straight lines and square corners, but not circles.
Regards,
Mike
Old 05-29-2008, 06:47 PM
well since i've stated the problem the machine will not create the same "hicup" again so who knows
the 35 amp tip is from my little cutter its a hobart airforce 625, 40 amp machine but the extended cut tip and electrode are rated for 35 amps
i have to use that for now cause my 3 phase service is slowly coming along and then i'll be able to use my hypertherm 1650 which is no compairsion to the 40 amp one
thanks
baker
Old 06-07-2008, 12:55 PM
tack1000 is on a distinguished road
Hi
You have not lost it, cose mine does the same thing.
Only sometime and only on smallish holes it wil learch forwards. It's still cutting but just gives a rough finish. It learches about 2 to 3mm. The g code is just a straight three line code with no fancy arcs.
I would also be interested in this one.
I'll post the code when I get to work. Maybe vidio it too if I can get it to do it. It's almast like a tight slider or rack sticking but I don't think so.
Tack1000
Old 06-08-2008, 10:59 PM
well it only did it on larger circles and ovals like 18x24. inches ive done 10inch circles with .5 holes and it does fine, just the bigger stuff that would be difficult
baker
  #11   Ban this user!
Old 06-09-2008, 11:24 AM
Originally Posted by tack1000 View Post
Hi
Tack1000
If you could take a video or post a g-code so I could look at the problem, it might help diagnose the problem.
Mike From Torchmate Mike@Torchmate Torchmate 40 02-24-2011 12:41 PM
Hey Mike.. l u k e Torchmate 14 12-03-2007 01:15 PM
? for Mike jb_swampfox Torchmate 4 07-02-2007 01:35 PM
What about Mike? warpedmephisto Industrial Hobbies (Support forum) 7 05-04-2006 09:09 PM
I want to be like MIKE Binderman CNC Plasma and Waterjet Machines 1 01-19-2005 12:01 AM
