| Torchmate Discuss Torchmate machines here! |
| What is the failure on the Start Cartridge? Is the plunger sticking closed, or is the copper piece corroded? Usual failures I see on those will be the cartridge sticking due to surface imperfections on the copper spring loaded tip, caused by moisture in the air lines.
__________________ Mike @ Torchmate.com | www.Torchmate.com Toll Free : (866) 571-1066 M-F 7:30am-4pm PST |
Low air pressure will typically decrease consumable life, however corrosion is usually caused by a contamination of the air supply. If you do not have a water filter and oil filter inline between the plasma cutters and the compressor, then I would recommend putting some in line and seeing how that improves the problem.
