Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 05-25-2008, 12:54 AM
I_wanna_CNC is on a distinguished road
Can I use a Nertajet Zip 5.0 Plasma Cutter on TM1 ?
I have a Nertajet ZIP 5 Plamsa Cutter and am just wanting to find out if there will be any issues using it with a TM1 Setup ?
Old 05-27-2008, 11:26 AM
Mike@Torchmate is on a distinguished road
Typically the only issues that come up with unknown plasma cutters is High Frequency electronic interference, and automatic height control.
If the cutter produces High Frequency noise, typically we would recommend shielding and grounding of all of the electronic equipment and the plasma cutter itself. We typically resell Thermal Dynamics and Hypertherm plasma cutters that are not High Frequency generating devices that work very well with out system, although we do have a few customers running High Frequency cutters, in the range of people who have done no shielding, to people who have shielded everything because the noise was causing communication problems.
The second issue was Arc Voltage, if you are never planning on putting an Automatic Height Control system on the table, then it wouldn't be an issue. But if you were planning on purchasing one of our AVHC systems, we would want to see if the plasma cutter had available to us the Raw Arc-Voltage take off points, and what the voltage range for those points is. Our height control operates in a range of 0-300 volts.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Plasma Cutter mikie CNC Plasma and Waterjet Machines 7 03-22-2011 07:56 AM
diy plasma cutter eloid CNC Plasma and Waterjet Machines 16 04-27-2010 08:52 PM
CNC Laser cutter versus CNC Plasma cutter? squale Laser Engraving & Cutting Machines 10 04-26-2009 05:59 PM
Plasma cutter cowleym Open Source Controller Boards 0 10-18-2007 05:28 PM
What is the best plasma cutter jpmassey CNC Plasma and Waterjet Machines 17 08-26-2007 02:15 PM
