| Torchmate Discuss Torchmate machines here! |
| Cutting speed test program I was watching Trucks! a few weeks ago and they just got a torchmate in their shop. Anyway, they were running it through its paces and mentioned a cut speed test program that you could run that would fine tune the cutting speed on a given material. They said it was downloadable from the torchmate site but I couldn't find it. Has anyone seen this software? I emailed sales@torchmate and never got a response, so maybe Mike or one of the other people here will know about it. Thanks. |
| You can download the FGC file for the line speed test at the link below. If you have any questions about it feel free to email us or call us. It would be better to email the support inbox for any questions regarding something non-sales related. support@torchmate.com http://fab-solutions.com/download_sites/downloads/
__________________ Mike @ Torchmate.com | www.Torchmate.com Toll Free : (866) 571-1066 M-F 7:30am-4pm PST |
Thanks for the info. Unrelated, and maybe I should post a new thread for this, but is there any FAQ for "tuning up" or post-assembly of a torchmate 3? I helped set up an 8x4 torchmate 3 and we have some places where we get backlash on the long dimension. I've tried to make the table as square as possible and as level as possible, but I still get some backlash. |
| What do you mean by misaligned? The left side gear rack (when looking down the long axis) is not lined up properly with the right side gear rack? Thanks. |
| By aligned I would mean the gear being parallel with the Rail that the gantry rides on, in a vertical alignment. If the rail to gear rack distance vary's over the length of the table, then the gear will ride in and out of the gear depending on location. If you bought your own rails, you might want to check and see if there is any bow to the rails.
I've measured the difference between the gear rails at both ends and they differ by maybe 1/16". I suppose we should make another attempt at seeing if we can get it closer to zero difference? Thanks. |
| 1/16" may not seem like much, but that is 1/16" of backlash that would reflect in your cut. Ideally you want the backlash to be consistently none across the table, some people develop spring loaded motor mounts to compensate for the gear rack being straight, but that is really just a band-aid for the problem. If you have the bolt in gear rack there is more then enough play to adjust the gear properly and get it to mesh all the way across the entire length of the table, on both sides.
| New speed testing program | Death Adder | Coding | 25 | 09-15-2006 09:40 AM |
| Mach2 - test ocx program shows running at only 96 pulses/sec | nikolatesla20 | Mach Mill | 6 | 05-29-2006 11:12 AM |
| How to speed up arc cutting? | Hack | TurboCNC | 11 | 11-06-2005 05:38 PM |
| Test cutting files. ( Webdings ) | ynneb | DIY-CNC Router Table Machines | 14 | 06-08-2004 02:32 AM |
| Stepper motor test program? | starCNC | General CAM Discussion | 17 | 06-02-2004 05:37 PM |
