Results 1 to 4 of 4
Thread: Rutex Z axis is anybody using one
    *Registered User*
    Apr 2008
    Is anybody using a rutex 953-000 Z axis control if so does it work well with torch mate software Thanks in advance Kirk
    Dec 2006
    Correct forum?
    Kirkln,
    Are you sure this is the forum you intended to ask your Rutex question? I'm guessing you were intending the Torchmate forum, not the Tormach forum.
    Rick
    *Registered User*
    Apr 2008
    Had a dislexic moment sorry guys how do I move it
    Jan 2007
    I am not aware of any of our customers using this particular height control PCB. The fact that the arc voltage has to be divided to less then 5 volts and that no motor or lifter station is provided sounds like a fair amount of work, to which our Height control will have 10 times the amount of features, perform better in sensing the true arc-voltage, and is a direct bolt on.
    Looking at the manual of that unit I believe our system can provide the contact start to initiate the height control's motions.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
  1. Will Rutex run these motors
    By hoju1301 in forum Servo Drives
    Last Post: 05-20-2006, 04:21 PM
  2. What to buy from rutex to get going........
    By Apples in forum Rutex Products
    Last Post: 03-01-2006, 11:05 AM
  3. Rutex Help
    By Apples in forum General Waterjet
    Last Post: 03-01-2005, 06:33 AM
  4. rutex
    By harolda in forum Servo Drives
    Last Post: 02-18-2005, 07:00 AM
  5. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 02:48 AM
