Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 03-26-2008, 08:30 AM
schoobie is on a distinguished road
Best Table Setup to Load Materials
Does any body has seen the table that can be lowered to load steel plates?
The question is related to a TM3 of 8' by 20' that I will be putting together.
So what is better, to have a fixed table or one that can be lowered?
Old 03-26-2008, 02:25 PM
Med-Pac is on a distinguished road
I've seen a similar table used to load stacks of material into a shear. If I remember right, the lift device was a hydraulic scissor lift. Might be easier to buy a forklift.
Mike
Old 06-08-2008, 01:24 PM
But with plates or sheets of material being 20' long, a forklift will not be enough to lift the plates evenly. The material will curve a lot.
Any other ideas?
Old 06-08-2008, 11:12 PM
bakerj99 is on a distinguished road
a two hoist crane that would make it easy
baker
Rotary Table as 4th Axis (setup help) fc911c Mach Mill 5 04-03-2009 11:08 AM
HELP selecting MOTOR size 1 AXIS 8 ft table with load 1000 lbs cjchands Mechanical Calculations/Engineering Design 1 08-07-2007 09:27 PM
Small Hobby Setup/Kit for Inlay Materials? turbo411 DIY-CNC Router Table Machines 1 01-01-2007 08:32 PM
Table setup - Axis invert horse Kellyware CAM 0 02-28-2006 09:45 AM
Rotary Table Outrigger setup walter Mechanical Calculations/Engineering Design 0 11-07-2005 09:19 PM
