Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 03-23-2008, 10:48 PM
schoobie is on a distinguished road
Table Height
I have seen several setups for tables and among other differences, I noticed that some tables are 10cms tall, while others are like 130cms tall.
Under what basis should I build a low table, versus building a tall table?
Old 03-24-2008, 11:17 AM
Mike@Torchmate is on a distinguished road
Material loading seems to be the big reason between higher and lower table. Keep in mind the lower table small part access becomes an issue when it falls through the table. The lowest table we have basically built off the ground, is a big 10x40 Torchmate 3 where they are doing strictly large plate cutting of large objects.
The hobbie users running gauge sheets and maybe thinner plate, usually has their table waist height.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Ideal table height for a mill ranchak General Metal Working Machines 2 11-20-2007 02:19 PM
Setting up Z axis tool holder height above table EL34 DIY-CNC Router Table Machines 3 07-27-2007 04:28 PM
CNC plasma table with height control...? Sperstad CNC Plasma and Waterjet Machines 3 06-27-2007 11:54 PM
Torch Height Control / Capacitive Height Control ahlbebuck Open Source Controller Boards 0 11-27-2006 02:32 PM
What is your opinion on optimal table height? Madclicker DIY-CNC Router Table Machines 6 12-03-2005 11:23 AM
