Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 03-09-2008, 06:34 PM
Kmanco's Avatar
Kmanco is on a distinguished road
water pan instal on bolt together 4x4
Had my local race car fabricater make me a 56x48x10 inch aluminum pan to bolt on my new t-mate table
Made leveling feet from 1/4 inch plate and 1/2x13 bolts i had
sandwiched the pan between bed supports and side rails
had fabricater put in 1/2 npt bung on left front for drain
What a difference the water makes for the dust factor..my lungs and shop are very happy now!
Old 03-11-2008, 07:03 PM
MBG MBG is offline
MBG is on a distinguished road
What are you just going to run plain water in that table?
Also, how do you plan on cleaning the table out?
Old 03-11-2008, 10:21 PM
Kmanco's Avatar
yes,right now i have plain water in it but i will add some washing soda in it soon,as far as cleaning it i have a hose spigot screwed in the bung with a domed stainless strainer glued over the pan outlet to keep the debris from entering the spigot,you can see it on bottom photo on left side of panI also plan to hang some 1/4 inch hardware cloth under bed slats to catch small drop outs to retreive them easier than from the murky depths of the bottom.
Old 03-12-2008, 03:29 PM
Normsthename is on a distinguished road
Wow, thats a lot of weight to add to your table.....
If you fill it 9" Deep it will have approx. 400kg (880 lb) of water
Why did you make it so deep?
My water table is 4" tall and I fill it upto 3" deep and it works great
Andy
Old 03-12-2008, 07:14 PM
Kmanco's Avatar
Andy,I tried to find info on the depth to make it but was unsure of the size.I did not know how deep the plasma would go in water and after the first cut i realized that 5 inchs would have been sufficient...keith
Old 03-12-2008, 08:19 PM
Hi Keith
Never mind, at least it works!
You will have one advantage over my tank.
Mine only holds approx. 16 gallons and yours holds approx. 88 gallons.
So it will take much longer to get murky with the horrible Plasma Dust
Andy
Old 03-20-2008, 02:00 AM
Blindchicken is on a distinguished road
Mine started out 8" deep on a 5x10 table. Now I think it is about 4" deep. Time to get a shovel...
-Mark
RFQ: Aluminum Bolt Pin warpedmephisto Employment Opportunity 13 08-07-2007 03:22 PM
bolt circles HIRAH Calibration & Measurement 1 07-10-2007 02:22 PM
Can I instal Win XP over Win 98 please? ImanCarrot Computers and Networking 18 02-12-2007 10:15 PM
Water transfer techniques for water table? Knut CNC Plasma and Waterjet Machines 3 02-02-2007 10:52 AM
PLEASE HELP Get this bolt out....please....Im desperate... diarmaid General Metalwork Discussion 25 07-01-2006 04:07 PM
