| Torchmate Discuss Torchmate machines here! |
| Can anyone help on making this in the Torchmate CAD program.. I need a 6 in circle with 2 bolt hole patterns in it.. First bolt hole pattern is 5 holes on a 5.50 inch circle pattern. (just like a rim mounting plate for a Jeep or Ford) Also want it to have 5 holes on a 4.50 inch pattern Here is a better explantion.. 1/4" plasma cut plate-steel has three different bolt patterns cut in one convenient plate. Bolt patterns are 5 on 4.5" (standard YJ, TJ, XJ, MJ), 5 on 5.5" (standard CJ) and 6 on 5.5. Studs are not included. Here is a link to an example picture.. http://www.nates4x4.com/catalog/images/tire_plates Thanks for any help! Jason |
| Included is an autocad drawing of the part you described above. Other than I didn't know what size bolt holes you wanted so I assumed 1/2" If you open it you will notice: 1) using a 6" outer diameter the bolt holes on the 5.5" pattern(s) will cut through the outer edge of the plate. Also one of the 4.5" 5 bolt holes & one of the 5.5" 6 bolt pattern holes also intersect. That can be fixed by rotating the 4.5" circle a bit. Hope this helps.
__________________ If it works.....Don't fix it! |
| I started with a 6" circle then centered a 5.5" circle to it then a 4.5". After that I snapped a single line from center across the 3 circles at 90 deg. I then drew a 1/2" circle at the intersection of the 5.5" & the straight line. Then use that single 1/2" circle to do a polar array of the 5 bolt pattern then again for the 6 bolt. For the 4.5" pattern I trimmed out all of the 5.5" bolt circle except 1 segment between any 2 of the 5 bolt hole pattern. I then used my snap commands again to snap a line between center of drawing to mid point of the remaining line segment. Again draw a 1/2" circle there & do a polar array of your 5 bolt holes again. It took way longer for me to type this than it did to do the drawing. There is nothing to the drawing but the very most basic of CAD commands. Although most of us here don't care a bit to help. You need to brus up on some cad skills. Several years ago I found a several week 3 night per week course at a community college on AutoCAD. Make you an expert NO. But it will get you going
| In the Torchmate CAD it is simply a matter of placing a single circle the size of the bolt hole you want on screen, add a set of guide lines, one vertical and one horizontal, select this circle and drag the center of the circle to this cross-hair. Use the array tool to define a number of 5 bolt holes, a radius, and then click ok. Simply repeat the process with another rotation of 6 bolt holes and a different radius. Draw a large radius circle, of the OD on the bracket you want, and then drag and drop the center onto the crosshair. Once the patterns are placed, simply remove the center bolt hole and you have your part.
__________________ Mike @ Torchmate.com | www.Torchmate.com Toll Free : (866) 571-1066 M-F 7:30am-4pm PST |
| Partial Bolt Hole Circle | barks | Okuma | 8 | 11-25-2009 03:41 AM |
| bolt hole circle | sanddrag | Employment Opportunity | 5 | 01-23-2007 07:52 AM |
| Bolt hole pattern with only a drill press | sanddrag | General Metalwork Discussion | 7 | 05-04-2006 02:41 PM |
| 200oz in Motor Bolt Pattern | jhwatts | Hobbycnc (Products) | 4 | 10-13-2005 10:40 AM |
