Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 12-02-2007, 05:05 PM
wsr5187 is on a distinguished road
torchmate small machine shop problems
we ahve a brand new torchmate small machine shop plasma.....I love it when it works correctly......however I am haveing a huge problem with the machine losing it origin (x/y zero).........when I xero out the corner on a new piece...it doesn't move to the correct location to start......i have to move away from the origing to start the program...it then works ok for a while...but then all of a suddent starts to move bacj to where it should be in the first place.........any ideas?
Old 12-03-2007, 12:51 PM
Mike@Torchmate is on a distinguished road
If it is cutting out the correct parts in the wrong location, that would typically indicate a position loss in at least one axis during the rapid travel movements to and from cuts. This setting is defined by the Maximum Feedrate setting under the Control-Machine-Feedrate/Ramping page. The default value is 300 i/pm. You can try changing the speed down in increments of 25 and test the table by zeroing out the program coordinates and then running a point move test in which ever axis was loosing position. Run the table out the length of the axis in a rapid travel speed, and then do a point move back to program zero at a rapid travel speed. The machine should return dead on to where it started, if it does not, or if it binds up during any of these movements, the speed may be too high.
I am going to assume that you have already checked the gear rack for dust/debris as well as checked all the set screws on both axis to make sure nothing is loose.
The problem typically occurs at the higher speeds due to the stepper motor's torque curve, having the least amount of power at it's top speeds, allowing any kind of resistance in the table to cause the motor to bind up. This is either caused by the gear meshing with the gear rack too tightly, or tighter in one area then another. (Gear rack not level with the rail, bowed in the center, etc...) The Cam followers should be supporting the weight of the gantry, not the spur gears. The gears should just be sitting lightly in the rack. Also if the gears on the driveshaft are positioned so that when one is meshed the other is not, and you force the other gear into the rack, it can cause enough resistance to make the motors bind. Or possibly if the Cam followers are setup to hold the driveshaft at an angle to the gear rack, this would also cause enough resistance to make them bind up.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Old 12-03-2007, 03:16 PM
Talking
thanks...that was it! now we are running good!
Old 01-02-2008, 10:02 AM
Trail Logic is on a distinguished road
Wow! great support! This has sold me on Torchmate, expect my order within the week!!
Looking for small run shop with carbon fiber experience mikencg Employment Opportunity 2 06-25-2006 12:50 AM
Looking for small shop space - NE Mass or SE NH InspirationTool Mentors & Apprentice Locator 1 03-20-2006 07:27 AM
Small Precision Machine Shop first CNC/CAD/CAM? GMTool General Metalwork Discussion 5 11-19-2005 12:31 AM
Would like to open small shop. speed33317 Haas Mills 14 06-30-2005 10:05 AM
