Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking Machines > CNC Plasma and Waterjet Machines > Torchmate
Torchmate Discuss Torchmate machines here!
Old 11-12-2007, 08:09 PM
JBurgess is on a distinguished road
Q for Mike on Plasma interface.
Do you or can you offer an interface that will wait for an arc initiated signal from the plasma before motion?
Old 11-13-2007, 12:36 PM
Mike@Torchmate is on a distinguished road
It should only be a matter of programming an input line for a normally open or normally closed circuit to accept the OK to move signal. Then in the software you would be able to create an m-code macro that would initiate M-code 50, then use an M101 IX command, where M101 means wait for tripped state on (I)nput line X. You would also have to define an input line to a Control type set to either normally open or normally closed.
With our current height control, there is no way to program an ok to move for it, so your height will always be timer based and if the cutter does not fire. However you can define a wait time for the M101 command so that if after X amount of seconds the input line is not tripped, it will signal a feed hold.
We are in testing with a prototype height control unit that will be able to accept OK to move signals.
Mike @ Torchmate.com | www.Torchmate.com
Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
Old 11-13-2007, 12:57 PM
Thanks Mike,
That works for me. Once my hieght control receives cut signal from motion controler, it establishes hieght then signals plasma to start, when it recieves the arc established signal its send OK to move to the motion control and starts following voltage to set hieght, The plasma sets the delay between pierce and arc established.
Mike From Torchmate Mike@Torchmate Torchmate 40 02-24-2011 12:41 PM
Hey Mike.. l u k e Torchmate 14 12-03-2007 01:15 PM
? for Mike jb_swampfox Torchmate 4 07-02-2007 01:35 PM
What about Mike? warpedmephisto Industrial Hobbies (Support forum) 7 05-04-2006 09:09 PM
I want to be like MIKE Binderman CNC Plasma and Waterjet Machines 1 01-19-2005 12:01 AM
