- Need Help!- Miller 2050 Spectrum CNC wire
Hello,
I am using a Miller Spectrum 2050 plasma cutter with a Fireball Comet CNC router, but no plasma arc is being produced. Gas is still flowing, so that is not the cause of the problem. I discovered the Miller's CNC wire is broken, so I am trying to replace it. Problem is I do not think the Miller Spectrum 2050 manual says anything about the CNC controller. I do not know if the CNC controller also needs to be replaced. Any tips on how to test the Miller Spectrum 2050's CNC controller circuit board?
Re: Miller 2050 Spectrum CNC wire
A few questions:
Has it ever produced an arc, even just a pilot arc?
Can you try the plasma cutter in a manual situation to eliminate the plasma cutter as the source of the problem? What I mean here is - can you connect a manual torch to the unit and first, just fire it in the air (Get a pilot arc). If that works, clamp the work lead to some plate and try and transfer an arc. If you are successful, then the issue isn't the plasma cutter.
- You may not post replies
- You may not edit your posts
Forum Rules
