I think that you may need to delete your original drawing lines from the file after making your toolpath.
-Brian
HI NEW HERE
the problem im having is eg
i make a drawing in torchmate cad-cam v9 and after i aply the toolpath ( tool path wizard) then export to the torchmate 4 machine driver program it doubles the cut path it cuts the same path twice
need help thanks
-Brian
Here is a reference to walk you through creating the tool path on your drawing.
The last step it covers is deleting the original drawing elements so you have only the tool path.
Creating Basic Tool Paths | Torchmate
-Brian
