- Need Help!- Plasma not following tool path correctly in torchmate 4
Hi All,
When I import dxf files into torchmate 4, i have problems torch not following tool path correctly. This problem only occures when importing dxf files that were created in torchmate cad. When I create files in Turbo CAD saved as dxf and imported to torchmate 4 have no problems at all.
TIA
Re: Plasma not following tool path correctly in torchmate 4
What exactly do you mean it is not following the tool path correctly? Are you exporting from Torchmate CAD as a .dxf (Polyarc). I was told by Torchmate that is what is recommended.
It's possible you have multiple tool paths overlapping each other.
- You may not post replies
- You may not edit your posts
Forum Rules
