I'll bite.
I guess it's your call on if the framework will support what you want to put on it.
Pitfalls? I'm not sure if you're thinking about the investment required, space required in the shop, or some other angle.
I've run Torchmate's software for a number of years. Yes the driver software does a nice job of producing G code from imported DXF files drawn from other CAD programs. You will want to import the DXF into Torchmate's CAD to create an offset cutting path with a leadin. One feature that Torchmate's CAD has is the ability for the operator to call the cutting sequence of the parts.
