Results 1 to 3 of 3
Thread: cooper cutting
    Jun 2010
    Mexico
    cooper cutting
    I need to cut 1/8" cooper plate with my CNC torchmate & cutmaster A80, any comment or suggestion?, what plasma tip, velocity and torch height recommendation?
    thanks
    Jan 2008
    Use the same specs that are listed in your A80 operators manual for cutting aluminum.....same height, same amperage and same consumables.....but start at about 60% of the aluminum speed. You will have to experiment a bit up or down....but that will get you in the ballpark.
    Jim Colt Hypertherm
    Quote Originally Posted by jcanales View Post
    thanks
    Apr 2003
    Sedona, AZ
    Been there, done that. Just be ready for some serious heat warping and your THC will get a workout.. Test (don't know your cutter model so can't offer specifics) and cut it the fastest you can and still get a suitable cut. Dropping the amperage may help keep it a little cooler, but it's a trade of amperage vs speed so find a happy medium. It's do-able
  1. Replies: 0
    Last Post: 01-08-2012, 11:00 AM
  2. Malaysia's Local Flame Cutting CNC, Plasma Cutting CNC Manufacturer : RobotshopCNC
    By MechanoSystems in forum Product and Manufacturer Announcements
    Last Post: 01-25-2010, 08:53 PM
  3. Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine
    By stephaniehamer in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 06-29-2009, 04:37 PM
  4. Can Watr jet cutting and laser cutting make endmills obsolete?
    By slashmaster in forum Benchtop Machines
    Last Post: 06-18-2009, 05:07 PM
  5. I need help about cutting heads which apply to apparel pattern cutting machine
    By sheepgrass in forum Mechanical Calculations/Engineering Design
    Last Post: 05-12-2006, 02:09 PM
