Results 1 to 3 of 3
Thread: Inside Line Cuttting
    Jan 2011
    united states
    Have a DXF that has several unattached lines on inside but cannot get the torchmate cad to define them does nay one know ow to solve this problem I was told to hold down on shift key and left click with mouse but this doe not work
    Jul 2006
    Try "make path". See if that does it.
    If not call torchmate, their tech support is pretty good when it comes to this stuff.
    Aug 2010
    Highlight the entire drawing (F3) and arange, break path, highlight the drawing again (F3) then arange, make path using .01 setting. Highlight the entire drawing again (F3) and arange, connect path.
    To ensure your file is correct for cutting use the view, "Show fill " selection to show how the file will look when cutting. If your happy with what you see, uncheck show fill and save the file. Then create your toolpath for exporting to a .dxf file.
  1. Need Help!- way to see the g code comands visualized line by line in Bobcad?
    By 777funk in forum BobCad-Cam
    Last Post: 04-07-2011, 08:48 PM
  2. Replies: 0
    Last Post: 01-13-2011, 09:07 PM
  3. Need A Quote- Aluminum sheet cuttting into small panels for electronics
    By rjmmusic in forum Employment Opportunity
    Last Post: 12-02-2008, 01:48 PM
  4. Need Help!- Help cuttting from the back side??
    By Skin in forum Mastercam
    Last Post: 04-16-2008, 09:45 PM
  5. cuttting head?
    By skaha in forum DIY CNC Router Table Machines
    Last Post: 10-17-2006, 11:59 PM
