Results 1 to 4 of 4
Thread: AVHC Problem
    Jan 2011
    united states
    Question AVHC Problem
    My torch height control will not I engage some times it will only move about 1/16 of inch before torch comes on an sometimes it will go down and touch metal before firing torch have cleaned the guides and screw on AVHC inspected to see if all cables are connected properly, torch fires in manual mode just started doing this periodically but getting worse machine is less than a year old only used minimal time not heavy production what else can I check to get working properly.
    Dec 2006
    Torch not firing
    There is a small black box, about the size of a pack of cigarettes that has a relay in it that controls the torch firing. I have taken it apart a few times and cleaned the contacts (with brown paper, no files) when my torch wouldn't fire on occassion. Try that. Bob.
    Jan 2011
    united states
    AVHC
    thanks jim but the problem was the AVHC was binding up when going down
    Oct 2011
    We had the same problem, despite cleaning the lifters over and over it was still binding up. After taking it apart a final time it became clear that the bearings had taken on a good deal of grit. We used 3in1 oil and repeatedly flooded them until serviceable. This might be the weak link in the AVHC design. Good luck,
    Dave
    Iron & Wire LLC
  1. Need Help!- AVHC Woes
    By pirateducky in forum Torchmate
    Last Post: 07-21-2011, 08:39 PM
  2. AVHC Module
    By cptcrust in forum Torchmate
    Last Post: 05-17-2011, 06:16 PM
  3. Need Help!- Problem of AVHC
    By reed in forum Torchmate
    Last Post: 11-11-2010, 02:02 PM
  4. Need Help!- AVHC
    By sandwarrior in forum Torchmate
    Last Post: 10-19-2010, 04:54 PM
  5. Need Help!- Problem of AVHC
    Last Post: 06-25-2008, 10:56 AM
