Here's the main problem we were having with accuracy. As you can see the spur gears were really worn out. The other two gears were not as worn, however were still allowing for some slack.
I also replaced the bushings. We were getting a lot of slop between the ob longed bushings and worn out spur gears.
I recommend you check, adjust and replace the bushings and spur gears often.
LinkBack URL
About LinkBacks
