Results 1 to 6 of 6
Thread: Cutting problem
    May 2006
    U.S.A.
    Angry Cutting problem
    Hi All,
    I am having a problem today with my TM3 4X8. I was trying to cut some large pieces. The table would traverse for a little ways diagonally as it should, then would stop going diagonally and just travel up the Y axis. I sounded a little strained. I checked all of the gears, collars and all of that. I am at a loss.
    Any help would be appreciated.
    Thanks, Mike Pennington
    Dec 2006
    Slag in your X axis
    Previously posted...check for a tiny bit of slag in the teeth of your gear rack. Bob.
    May 2006
    U.S.A.
    Smile
    Quote Originally Posted by jmsrbrt View Post
    Thanks for the reply. I cleaned the racks a couple of days ago. They are pretty much out of the way on the TM3.
    Mike
    May 2006
    U.S.A.
    Smile
    Quote Originally Posted by aicomp View Post
    Hi All,
    Hi All,
    I just solved the problem with the diagonal moves. I took the gantry apart and cleaned everything. I reassembled as per the original instructions and realigned. It works great again.I still have a couple of noisy motors, so I will get a couple of new ones and keep these as spares. Maybe even have them rebuilt if I can find a place that does that.
    Thanks for all of the help.
    Mike Pennington
    May 2008
    united states
    sounds like you need to check the squareness of your gantry to the table
    May 2006
    U.S.A.
    Quote Originally Posted by bakerj99 View Post
    I did that and it is OK now. I don't know what took it out of square though. I used it for two years with no problems.
    Mike
    1. Need Help!- OiM cutting feedrate problem
      By Purdue Guy in forum Fanuc
      Last Post: 04-01-2011, 12:04 AM
    2. Arc cutting problem
      By theshed in forum Granite Devices
      Last Post: 11-01-2010, 08:56 PM
    3. xy cutting problem
      By melzer in forum Fadal
      Last Post: 08-25-2010, 09:27 AM
    4. problem in cutting curves
      By fawzy_mahmoud in forum Linear and Rotary Motion
      Last Post: 12-13-2006, 04:26 PM
    5. Groove Cutting Problem
      By pprichard in forum General Metalwork Discussion
      Last Post: 01-18-2006, 09:53 AM
