Most people said they would have gone bigger hence the 5x10
Also most said a bigger/ better plasma.
Is the cable track really worth $358.08
Are the 144" HR Rail Ground for 10' long Torchmate 2 Table worth $800 Is it going to make a big difference in cut quality as far as accuracy and repeatability?
Then there's the Torchmate Interface for Plasma @ $295, would this still be needed if I went with the Powermax 85 or just necessary for plasma machines without the
cnc port? Hopefully Jim with chime in on that ?
Are there any other suggestions for getting the most for my $?
Thanks again, Modelaratrod
