Results 1 to 6 of 6
Thread: Problem when running
    Jan 2011
    united states
    When starting a program machine will move and go through the program but torch willnot ignight I think its in the program setup but cannot get it turn torch on
    Dec 2006
    Is this a new problem, i.e., first time running the machine, or has it worked in the past ands not now? Does the torch move dwon and contact the material then retract a bit, or not move down at all? If it's the latter, check the fuse in the torch height controller box.
    Jan 2011
    united states
    Rstrange
    No this happen when I was trying to set up homing in thr programming page I reset back toriginal settings but dont fire it does come down but does not fire torch. On the input line page I now have line1=pierce=open line 2=feed hold=open line 3 is blank but is open cannot find a way to close it
    Jan 2011
    united states
    Rstrange
    Dec 2006
    I'm not following. Which cutting program are you using, Torchmate 2 or 3? 2 is the one for the serial signal generators, 3 is for the USB generators. I have both and I can't find the "homing" you're refrring to. There is PROGRAMMING>M-CODE DEFINITIONS where I have lines to turn the torch on and off, but it doesn't "home" the torch. Tell me which program you're using, 2 or 3, and how you navigate to the page where your settings are. Bob.
    Jan 2011
    united states
    Thanks for the help got it up and running had m-code input error M101 I1
    1. Need Help!- problem running program
      By mehdiF in forum Fanuc
      Last Post: 11-22-2010, 02:27 PM
    2. Need Help!- Tool offset problem when running
      By lifestill in forum Machines running Mach Software
      Last Post: 02-25-2010, 01:02 PM
    3. Need Help!- problem running mastercam 9.1 and x4mu2 on the same system
      By fishernimr in forum Mastercam
      Last Post: 02-05-2010, 02:37 PM
    4. Just got my Tormach up and running and having a problem, need some help
      By mike@newera in forum Tormach Personal CNC Mill
      Last Post: 12-25-2008, 12:50 PM
