did u check the fuse in the avhc box?
bakerj99
So I'm gonna go batty....table has been working pretty good. The machine torch holder setup is a little worn out and has a little play. Saturday we made a bracket to change the angle so that we could mount the plate marker and life was good. Then we cut out several things fine, and then went to cut out a sign and the ahvc hung up on one letter, and after that everything went down hill. If i use the control box to move it up and down its fine but if I turn the plasma on, like to set pierce height, its opposite. Plasma on torch goes up....plasma off torch dives down into materiel. I didn't change anything (that I am aware of or on purpose). It started doing this after it hung up. I am currently using the torchmate red display AVHC. I am using a hypertherm 1650.
bakerj99
Fuse was fine. After talking with torchmate the recommend a gaurd reset...which is just unplugging the whole unit for ten minutes or so. Works fine now.
