Results 1 to 4 of 4
Thread: Table Top
    Jun 2010
    Table Top
    Hi, I posted this in the torchmate thread as well, but I thought I'd post it here since it isn't really specific to the torchmate. I've been lurking around on these threads since we got our machine a few months ago, but this is my first post.
    My dad recently bought a torchmate 2x2, and neither of us are very experienced with CNC but we're getting better. I would like to do woodworking with it, and I have had some success so far, but I was wondering what the best table top material is? I'm doing a lot of through cutting so I've just been putting some MDF on and clamping my pieces to that, but I feel like it is creating a lot of waste because it is tough to clamp the piece except on the edge. I like using the MDF because it is cheap so I can wreck it by cutting through and just replace it, but I was wondering if anyone had any tips or other table tops, etc.?
    Thanks!
    Aug 2007
    mdf is good spoiler board. you can run wood screws directly into if for clamping if you can't get onto edges. also might want to look at some t-slot sets. you can get them in lots of sizes shapes.
    Jan 2007
    I would agree, MDF is a good spoiler board. It does get cut and eventually will need to be replaced, but it's easy on the bit and a smooth flat surface to put stuff on.
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
    Nov 2008
    we have a cnc router over in the wood shop, the teacher over there just uses finish nails to pin the corners down to his plywood top that is clamped with T-bolts to the top.
  1. another 4 x 4 table
    By Steve-M in forum Plasma, EDM and other similar machine Project Log
    Last Post: 06-24-2009, 04:17 AM
  2. Replies: 7
    Last Post: 06-04-2009, 08:34 AM
  3. DYNA CNC TABLE WITH WATER TABLE
    By DISCONNECTED in forum General Waterjet
    Last Post: 06-06-2008, 09:04 PM
  4. open table vs closed-table gantry setups
    By nicanor76 in forum DIY CNC Router Table Machines
    Last Post: 04-21-2008, 01:35 PM
  5. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 01:21 PM
