Dear All,
I'am working on T3 5x10, AVHC and Hypertherm 1250 Plasma cutting machine. Normally we make .DXF files in AutoCAD and after that import them into T3.
Problem is that when we start cutting multiple objects e.g square and circles etc, as we press 'Torch' button from "AUX PANEL" of Torchmate control software, torch starts moving downward to the object and immediately fires the spark and pierce the sheet but don't move on any X or Y axis until I press manually 'START' button from the "G-Code PANEL" of Torchmate control software to start the cutting (While I've made changes in M-Code definition and M-Code Execution as per instruction in given in the Help to start cutting automatically). Then it starts its motion on given axis and complete the cut of the required object. Without closing the spark and retracting back torch to its normal or safe height it continues its Rapid move to the next object while cutting and damaging the sheet and complete the drawing and stops cutting at point where it started the program. During this whole process spark remains on and does not stop automatically.
I'm too much confused with its behaviour
, I'm unable to figure out the accurate parameter settings in AVHC and Torchmate Control Software.
Please, help me in resolving the issue.
Thanks in Advance
