Results 1 to 2 of 2
Thread: Reducing nodes
    Nov 2009
    Reducing nodes
    Mike,
    Could you give me a run through on reducing nodes.
    Maybe something that is less time consuming
    Torchmate is the greatest and so is tech support, just thought others might be interested in this also.
    Thanks for all you help.
    Jan 2007
    I'll explain it in a common situation I see here.
    Say you scan an image in, and you set the scan tolerances fairly tight to get the best looking object. The outside scans great, but the inside circles have a lot of nodes to them, because it traced out the pixels. To thin out the nodes, or remove half at one time, click and drag a selection box around all the nodes and turn them all red. Press the U key on the keyboard, and it will deselect every other node. Hit it again to deselect half of the nodes that are still selected. Press the delete key to thin them out.
    Now if there are important nodes that you want to keep, hold the shift key down and de-select them before deleting.
    -Mike
    Mike @ Torchmate.com | www.Torchmate.com
    Toll Free : (866) 571-1066 M-F 7:30am-4pm PST
  1. Reducing RF Interference
    By stirling in forum Gecko Drives
    Last Post: 04-09-2010, 11:40 AM
  2. G73/83 Reducing peck
    By mattpatt in forum Fanuc
    Last Post: 03-24-2009, 08:03 AM
  3. reducing output on psu.
    By thx1138 in forum General Electronics Discussion
    Last Post: 09-17-2006, 04:47 PM
  4. Reducing amperage?
    By stdly in forum General Electronics Discussion
    Last Post: 02-22-2006, 10:23 PM
