Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Toolgrinding & Toolgrinding Machines
Toolgrinding & Toolgrinding Machines Discuss Toolgrinding & Toolgrinding Machines here!
Old 02-01-2009, 11:53 PM
Jim Estes is on a distinguished road
What can you do with a DECKEL SO grinder?
I have an old Deckel SO type single lip cutter grinder. I use it all the time making single lip, cutters, tapered cutters and even solid carbide drills. I have seen accessories for sharpening twist drills before, but I was wondering if it can be used to sharpen endmills and reamers.
Also, is there a good source for diamond grinding wheels for the Deckel SO?
Thanks,
Jim Estes
www.maverickmoldandtool.com
Old 02-02-2009, 09:18 AM
Karl Ericksen is on a distinguished road
Jim, my company actually sells these models on a regular basis. They are common place for in Carbide Header Die Tool Rooms for Sharpening Spade Drills. My company actually stocks Diamond Grinding wheels for this machine. Feel free to contact me with any questions.
http://www.rockform.com/Deckel%20S.O...ccessories.htm
Old 02-02-2009, 07:20 PM
John_B is on a distinguished road
You can find replacement diamond grinding wheels and cups at most machinist supply houses like MSC Industrial Supply or Rex Supply also. I use a different brand machine, but I've found that I can get wheel much less expensively at the supply houses versus the distributor of the machine parts.
Regards,
John B
Deckel model SO cutter grinder ErnieD Deckel, Maho, Aciera, Abene Mills 26 11-23-2011 08:47 AM
looking for swisher grinder or swisher type of grinder JMG1 Toolgrinding & Toolgrinding Machines 1 09-04-2008 08:58 AM
Deckel GNC-1 Dirkos Deckel, Maho, Aciera, Abene Mills 1 09-02-2008 07:08 AM
Deckel FP1 (CNC?) stephaan Deckel, Maho, Aciera, Abene Mills 2 02-04-2008 10:52 AM
Deckel SO-E cutter grinder regrind laurentian Deckel, Maho, Aciera, Abene Mills 0 02-19-2007 05:30 PM
