Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Toolgrinding & Toolgrinding Machines
Toolgrinding & Toolgrinding Machines Discuss Toolgrinding & Toolgrinding Machines here!
Old 06-16-2008, 11:14 AM
dave90 is on a distinguished road
Wishbone Drill Sharpener
I wish to make personal contact with Bill C and Handlewanker about the long discussions about the wishbone drill sharpener, that were in this forum in 2003 and 2008. I have been trying to purchase such a tool, without success. I would appreciate personal contact for the exchange of photographs, drawings and a detailed description of the setup and use of the tool. Please contact me direct if possible at my address of dave90@adam.com.au
Thanks in advance from Dave Ticehurst.
Old 06-16-2008, 03:50 PM
neilw20's Avatar
neilw20 is on a distinguished road
Talking My draft version.
Dave.
Ian had shown me a pictures so I had to create one to try it out.
I can sharpen 0.4mm solid carbide drills in a minute or 2 now.
The trick was learning how much to grind off.
1). Grind the end flat and square using your finger for support.
2). Grind the first flat. Temperature rise on finger says when it is done !
3). Grind the second flat. Temperature rise on finger says when it is done !
4). Inspect and if failed, go back a few steps.
5). Lap the flats on a diamond lap.
Sharpening drill bits by hand
3D model, some Gcode and pdf. That's my first attempt. Ian got curious and traveled almost 1 hour to make sure it was real. I saw his original one in it's case along with all the accessories.
Super X3. 3600rpm. Two possible way to fix things: The right way or the other way.
drill sharpener BeeleJuice General Metalwork Discussion 5 01-08-2009 04:44 PM
Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press. Geof General Metalwork Discussion 47 02-01-2008 02:32 PM
Chevalier Endmill sharpener Chad G General Metalwork Discussion 1 12-11-2007 01:57 PM
fanuc drill mate / robo drill post for enroute? goodplastics Post Processor Files 0 07-19-2007 06:49 PM
Can I drill AISI 1020 plate steel with a drill bit? Apples General Metalwork Discussion 2 02-01-2006 12:15 PM
