Results 1 to 10 of 10
Thread: Engraving
    May 2003
    Melbourne,Australia
    Question Engraving
    What is the best way to grind a cutter to do engraving in tool steel.
    At present I use carbide and grind three flats equally spaced at around 15 degrees on a tool and cutter grinder to a point.
    The tool doesn't last long and i was after some advice.
    Would 4 flets be better?
    Angle is not important engraving is only 0,2 deep (.008").
    Thanks in advance
    Registered hardmill's Avatar
    Mar 2003
    If....
    If your using a deckel to sharpen tools then i always
    use a single lip tool. I've ground tips as small as
    .003 x 10degs. And i'd also use Moly-dee. If you must
    go the route your going i would do a 6 sided cutter,
    rather than 3.
    PEACE
    May 2003
    Melbourne,Australia
    Single lip do you mean by grinding a flat to the centre line?
    Moly-Dee?????
    Mar 2003
    Yes
    Exactly. And moly-dee is a heavy oil made by Castrol,
    Also happens to be the best for engraving anything
    hard.
    May 2003
    Melbourne,Australia
    Thanks Hardmill.
    Next time i have an engraving job i'll make d-bit like you sugested.
    Apr 2003
    Kalamazoo, MI
    The single lip cutter is a good way to go. I have one company that likes using 1/16" 2fl ball mills, but I don't think they are engraving as small as you are. They are doing it on a Haas Machining Ctr. Heat treated 17-4 stainless.
    Where Your Quality Counts!
    www.toolgrinder.com
    durkee@toolgrinder.com
  7. #7
    Registered WOODKNACK's Avatar
    Mar 2003
    Maine
    Anybody got any pictures of a bit they ground down?
    My little piece of the web!
    http://users.adelphia.net/~wjdupont
  8. #8
    Apr 2003
    Kalamazoo, MI
    If no one has one to take a picture of, I could grind one up and post a pic after the holiday, if someone will kick a reminder to me by posting it here. Don't have the time to mess with it right now since I'm trying to get Friday off. Be glad to do it next week.
    Keith
    www.toolgrinder.com
  9. #9
    Mar 2003
    Maine
    That would be great. Thanks..
  10. #10
    May 2003
    Melbourne,Australia
    i would love 2 c it thx
  1. Using CNC Mill for Engraving
    By studysession in forum General Metal Working Machines
    Last Post: 10-22-2006, 10:15 PM
  2. Engraving machine help
    By Marc in forum DIY CNC Router Table Machines
    Last Post: 07-01-2006, 09:08 PM
  3. Engraving Software
    By The Wizard in forum General CAM Discussion
    Last Post: 03-29-2005, 06:38 AM
  4. Engraving
    By Hack in forum General CAM Discussion
    Last Post: 03-25-2005, 09:53 AM
  5. Intro + engraving bits
    By Swede in forum General Metal Working Machines
    Last Post: 02-07-2004, 03:47 PM
