Thanks for the reply.
I talked to a guy that grinds tooling for a living and he also said that he grinds these by hand. He actually said that he grinds most gashes by hand even on the shorter endmills. For me doing it by hand just doesn't come out as nice as using a machine.
I have a little shop here at home that I actually started to regrind the endmills that we use where I work. I just ground these in the evenings and on weekends.
I had an old covel cutter grinder with worn out spindle bearings that I paid $35.00 for. So I mounted a small index head off to the side of the table. Then I mounted a surface grinder spindle to the top of the wheel head which allowed me to grind the gash on a very long endmill. Now I actually do more machining than grinding in my home shop and a few years ago, I bought a cnc mill. To make room for it, the old covel had to go and now I kind of miss it. I still have two cincinnati #2s but they just won't grind the gash on those long endmills like the old covel would. |
