Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Toolgrinding & Toolgrinding Machines
Toolgrinding & Toolgrinding Machines Discuss Toolgrinding & Toolgrinding Machines here!
Old 12-16-2007, 08:34 PM
sizmo is on a distinguished road
Question using a air flow fixture
Help! can some one give some advise . Know a little about cutter grinding but only what I have learned on my own are read about .
Have a Harig air bearing spindle off e-bay. Know some what how to use it . But on the bracket that mounts to the face that holes the rod for the micrometer finger it rotates with a clamp screw and is marked off in degrees. What is it for and what are the degree marks for. Does it have something to do with rotating the finger to grind the secondary clearance on an end mill are do you still have th drop the finger down for that. Thanks in advance for any and all answers.
Every Mans Work Is A Portrait Of Himself
Old 12-28-2007, 12:36 PM
sima is on a distinguished road
those degree marks have everything to do with your cutting angles on your tool. but first has to be setup correctly first thing is to indicate your airbar in vertical and horizontaly put your indicator on the wheel head to indicate correctly set table and airbar to 0 and indicate in.
when that is done you need to set your finger personaly i do not care for the finger that comes with the airbars i make a solid carbide one.
to set your finger if you will notice it is off set.
put the short side towards your cup wheel set your clamp degrees to 0
and and put a small center in your airbar move you bar out to close to the finger with the cross feed at the bottom of the clamp bring the finger in to line up with the center you want the point of the finger the same hieght as the center that is in the airbar this will set the 0 degree on the airbar the when you set the clamp on any degree on the clamp ring that will be the degree you will put on your tool.
when you line finger to you cup wheel set top of finger to center of cup wheel and cup wheel should be 1 to 2 degree in front of center to protrude a sharp edge for grinding.
follow these steps and you should be able to sharpen ods on your endmills.
one more tip harig is an excellent airbar but prong to rust clean with mineral spirits and try not to touch air bar the oil in you hands will rust it keep covered with dry cloth when not in use and never move with out air attached
i hope this helps
sima
Old 01-27-2008, 07:38 PM
Thanks this is what I was looking for Thanks again Sizmo
Old 07-28-2010, 05:47 PM
CSW_Grinderman is on a distinguished road
i have a question???
Im also using an airbar and i was wondering if anyone knows of a chart or anything that tells you the degrees of what the primary and secondary angles are on all sizes of end mills???
Flow chopper Tommy2Times Hobby Discussion 0 12-09-2007 01:46 PM
2 flow post jas6142 Post Processor Files 0 07-11-2007 09:05 AM
air flow ... CNC machine emceul General Metal Working Machines 0 04-20-2007 03:20 AM
flow meter larry53 Welding, Brazing, Soldering, Sealing 3 03-12-2007 04:24 PM
Flow Waterjet Flow_ken CNC Plasma and Waterjet Machines 4 01-15-2006 03:38 PM
