the more expesive machine will give you tighter machining, better precision,
and will stay that way longer, with less repairs.
walter makes a good saw blade grinder, probably one of the more expensive ones. www.grinding.com
look at how many hours you will be grinding 1 ,2 or 3shifts.
at look at your precision, tolerances and stuff.
you may have the best results with a cheaper machine.
LinkBack URL
About LinkBacks
