Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Toolgrinding & Toolgrinding Machines
Toolgrinding & Toolgrinding Machines Discuss Toolgrinding & Toolgrinding Machines here!
Old 04-29-2007, 03:23 AM
brainlessme is on a distinguished road
Reshrpening Solid Carbide Tools
Hi all, I use a CNC T&CG, needed some help on ideas to grind a good end mill. always end up with some problem or the other....either the finish is bad or the life aint tat good or the tool sparks a lot...any clues.....
how deep does a end mill gash have to be and how wide9 usually do 3, 4 and 6 flute cutters)...is there a percentage related to the dia of the tool, or you guys just look at it and say tat looks good,,,,unforn for a novice like me everythin looks " good"!!!
Tools for machining solid carbon (not carbon fiber)-more posted camcutter Composites, Exotic Metals etc 5 04-27-2007 07:23 PM
clamping of solid carbide drills dhiruj Metal Working Tooling 11 03-27-2007 02:02 PM
tool adaptor for solid carbide drills dhiruj General Metalwork Discussion 0 03-19-2007 03:52 PM
Will a solid carbide bit cut faster that a straight cutting bit? Apples DIY-CNC Router Table Machines 1 09-11-2006 08:10 AM
Guhring Solid Carbide Drills bma137 General Metalwork Discussion 14 08-16-2006 08:13 PM
