Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Toolgrinding & Toolgrinding Machines
Toolgrinding & Toolgrinding Machines Discuss Toolgrinding & Toolgrinding Machines here!
Old 04-27-2007, 11:01 AM
brainlessme is on a distinguished road
Resharpening of Drills end mills
I just got a cnc tool and cutter grinder....isnt it easier to grind some of the stuff on a manual one??? i get this feeling and i think i may be doing something wrong...but i can look at the tool and say if its good or bad..but i dont know the values to put on my cnc to make em look good....stupid..!!!! yes i know...but....
Old 04-27-2007, 11:16 AM
sanjiv is on a distinguished road
you might have purchaserd this machine for some specific need or may have somespecial requirment.
Old 04-27-2007, 11:33 AM
cb1 cb1 is offline
cb1 is on a distinguished road
what machine did you buy?
Old 04-27-2007, 11:41 AM
cb1 cb1 is offline
i just saw, you have a jungner
axial rake on the end , try 1dg
the tool must be rubbing somewhere for it to spark, check behind the rad.
whats your clearance on the dia.?
try 9 and and 20dg.
the rake is probably not the reason for the spark.
Old 04-29-2007, 02:33 AM
Sparking
Hey cb1,
Thanks for the info..... the relief behind the radius (of 0.8mm) is just a primary relief of 10deg with a land of 0.8mm
on od and face reilief are 10deg/21 deg and 7deg and21deg respectively.....
parabolic drills Machine1 Hard and High Speed Machining 18 06-11-2008 10:22 PM
PCB Drills aggie_67 General Electronics Discussion 7 03-07-2007 10:47 AM
resharpening zcases CNC Tooling 8 11-16-2006 06:34 AM
Face Mills intstead of end mills balal General Metalwork Discussion 8 07-01-2006 01:35 AM
carbide drills MBG General Metalwork Discussion 30 10-23-2005 09:03 AM
