Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Toolgrinding & Toolgrinding Machines
Toolgrinding & Toolgrinding Machines Discuss Toolgrinding & Toolgrinding Machines here!
Old 01-23-2004, 12:01 AM
ezland00 is on a distinguished road
Home made taps qustion
Will the homemade tap works on Brass or any kind metial?
Old 01-23-2004, 12:06 AM
pack rat is on a distinguished road
Balsaman and kong made their own ACME taps and used them on derlin plastic and acetal but not brass. Come to think of it I never seen one made in brass by homemade ACME tap. Good question.
Old 01-23-2004, 12:07 AM
I dont know where those two smilies came from. Sorry
Old 01-23-2004, 12:29 AM
cbcnc is on a distinguished road
ezland,
Well, sort of. It's slow and I didn't go very far when I tried it. Also I'm not sure how long the cold rolled steel would hold up.
When I made my tap I tapered it in my drill press with a file. Then I cut two grooves in it on my tablesaw with a composition metal cutting blade.
I don't think that the geometry of the flutes is perfect and you could do better with some careful Dremel/grinder work. Also you could probably harden it somewhat with heat treatment and a quench.
There are some relatively inexpensive acme taps from _Wholesale Tool that would work better or be less work to get it right.
Chris
Old 01-23-2004, 04:44 AM
Hobbiest is on a distinguished road
punch "case hardening home foundry" into a search engine. I know I have seen it on some HF website but can't remember with one.
Stop talking about it and do it already!!!!!
Old 01-23-2004, 07:34 AM
HuFlungDung's Avatar
Moderator
Packrat, if you are about where the came from, don't :frown: I would that there is nothing with what you wrote. I have an that seems but is worth a : It must be the smilies code on this forum.
Old 01-23-2004, 07:35 AM
BIG AL is on a distinguished road
I don't think adding that crap on this site is appropiate. That is aimed at Hobbiest post with the crap link.
Old 01-23-2004, 07:40 AM
Moderator
Relax, Al, I was just demonstrating what can happen by accident if your post contains some "secret code"
Oops, I see your message was directed elsewhere. Maybe he meant angelfire?
Old 01-23-2004, 07:43 AM
Many thanks HU, my blood pressure was going thru the roof.
Old 01-23-2004, 08:10 AM
Moderator
Re: the tapping question: it is tough enough to cut threads in brass with a commercial tap. Brass seems soft up until you try to cut it with a dull tool, then for some reason it seems as hard as glass
Splurge and buy yourself a real acme tap. Wear it on a chain around your neck and thank your wife for the necklace
You should have seen the look on my wife's face when I gave her a necklace of used up CBN inserts. I thought, "heck these are just as hard as diamond" and I hate to throw them away. But, I never even got to first base, thankless woman!
  #11   Ban this user!
Old 01-23-2004, 01:20 PM
Tight panties?
Huh? So sorry...but at two in the morning I find it hard to think of links, thats why it was a "crap" search, and not a "crap link". Take a pill dude.
  #12   Ban this user!
Old 01-23-2004, 01:37 PM
kong is on a distinguished road
Hobbiest, since your post was edited, did you actualy click on the link you gave, or do you not realize it was a link to dirty porn?!
Don't mean to argue, just making sure!
New home made MadVac CNC router oneyaker DIY-CNC Router Table Machines 20 02-05-2011 06:37 AM
5-Axis Home made Router paulried Commercial CNC Wood Routers 12 04-23-2010 08:03 PM
Any home made cnc laser's out there? CNCadmin Laser Engraving & Cutting Machines 3 04-08-2009 06:46 PM
First tool for the tiny lathe (home made) pics Stevie General Metal Working Machines 5 05-02-2004 11:24 AM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 06:54 PM
