Should the retention nut be tight.Similar Threads: Walter CNC GrindersNeed Help!- Walter HMC 500 Problemas en WALTER HMC 400Need Help!- How do you resharpen a tap using the Walter hmc 500? walter GC8
Are you asking about the retention nut on the chuck? yes that should be tight. just hand tight.
Originally Posted by cb1 Are you asking about the retention nut on the chuck? yes that should be tight. just hand tight. Yes I'm talking about the Chuck retention nut. Thank you.
View Tag Cloud
Forum Rules
