Hi Denno,
I looked up the specs on the internet and found the following:
Brand New Desktop CNC Engraver/Router
■ Features
X,Y and Z axis all adopt Line guide rails and tightening devices to guarantee precision.
The Whole Cast-iron structure, which moves steadily and little vibration.
Imported ball bearing lead screw from Germany ensures engraving precision.
Dual-core CPU and advanced DDA curves and straight lines calculating method to assure better quality.
High power driving components which are powerful, less noisy and more reliable.
Multi data input way (USB & Memory Disk both acceptable).
With the function of memorizing when the power is sudden cut off
■ Parameters
Model SG-3226C
Travel of engraving 300x250x80mm (11.8"x10"x3.1")
Height of Z axis 80mm
Spindle Power 800W (the 1200w and 1500w spindle is optional)
Port USB/Serial
Max run speed 4500mm/min
Min feeding speed 1mm/s
Resolution(X,Y,Z) 0.0125mm
Max speed of Spindle 6000-24000rpm
Format of command HP-GL,G code
Power 500w(void load)
Dimension 550x600x525mm
Power source DC220V/±10% 50HZ
Gross weight 120KG,net 80kg
■ Application Fields
It is applicable to the industries of artwork processing, advertising and stamp making. E.g.: instrument processing and cutting of metal signs, ironing boards, atomic stamps, carbon plate in battery, copper stamp and small artworks.
■ Shipping & Payment Terms
Default SHIPPING WORLDWIDE BY Sea(recommended),OTHER SHIPPING WAY WILL BE ALSO ACCEPTED.
SHIPPING COST HERE IS TO TYPIC PORTS NOT FOR ALL PORTS.LET ME KNOW YOUR ARRIVAL SEAPORT BEFORE BIDDING.
SENDING WILL BE IN 5 WORKING DAYS AFTER THE CLEARED PAYMENT.
It states above that it can run G-Code.
If I was you I would get rid of the provided software and either buy Mach3 ArtSoft USA - Home of Mach3 and LazyCam or WinCNC Mack3 is cheaper.
All the best
Mick
LinkBack URL
About LinkBacks
