Results 1 to 6 of 6
Thread: any one involved in marquetry work
    Jan 2007
    kuwait
    i am new in this marquetry work. i hav a laser cutting machine, which i would use 4 cutting veneer but i have too much issues while cutting veneer paper using laser, so any body involved in such type of work please get me some information
    any help would be apprecieatable.
    Dec 2010
    If you can get a hand operated fret saw such as:
    File:Fretsaw.jpg - Wikipedia, the free encyclopedia
    And hold it at a 13* degree angle-either right or left and stack your veneer on top of each other to cut through the whole stack at once-as in your background piece and another -they will fit perfectly inside one another and leave a crisp edge. It takes a little practice but you will get the hang of it pretty fast. It is fun to do and can become quite elaborate in detail.
    Have fun!
    Oct 2010
    What are the problems with using the laser?
    Jan 2007
    kuwait
    When i work with laser machine , i find difficulties
    how can i cut veneer paper for complicated designs, when it starts cutting the veneer seems to bending,even if i cut how can i remove all the design cut veneer to sticking in other laminates,i dont know the procedure , leading to damage of the veneer
    Please give valuable ideas
    Jan 2007
    Have you thought of making a sandwich? Solid wood, plywood or fiber board above and below the laminate and then cut it?
    Mar 2013
    Sorry i have no idea about marquetry work so i can't help you but i am found this website in Google and hope this will be helpful for you.
    skynet.ie/marquetry/?page_id=65 . here you can find some guidelines about marquetry work.
    1. Work holding options to hold thin round work? .024, .046 etc
      By KyleH2 in forum General Metalwork Discussion
      Last Post: 06-07-2010, 02:22 PM
    2. Newbie- Work Planes / Work Coordinates
      By MICFDI in forum Esprit
      Last Post: 05-12-2008, 12:35 AM
    3. Replies: 3
      Last Post: 10-25-2006, 04:27 AM
    4. Art work
      By Art Ransom in forum Employment Opportunity
      Last Post: 10-16-2006, 10:01 AM
    5. rail selection (forces involved in cutting)
      By daedalus in forum Linear and Rotary Motion
      Last Post: 11-17-2005, 10:30 AM
