- Help with 2.5d facet design
I have a customer that needs a speaker baffle cut with facets on three sides. I have a working 3D raster program that works but it has obvious issues like raster lines and it takes a while to cut. The part is 9"x14" rectangle has a 70 deg angle from top edge leaving about 1/8" margin, and two side cuts at 60 deg angles that meet.
Any ideas on how to cut this more efficiently?
- You may not post replies
- You may not edit your posts
Forum Rules
