- How to manual adjust focus distance
Although auto focus function is quite cool, sometimes you still need to use the manual focus function. When you use the rotary attachment, this will be quite useful.
You can unscrew the laser head and then adjust the focus by using a triangular rule and you can also control the motorized table up/down to adjust the focus. This function also makes the laser cutter quite flexible under many conditions.
- You may not post replies
- You may not edit your posts
Forum Rules
