Results 1 to 11 of 11
Thread: CNC 5-axis VMC with Siemens 840 control
    Nov 2006
    Bahrain
    We have a cnc 5-axis VMC machine with siemens 840 Di controll.Trying to bring the machine to its zero position.Following errors appears.
    4th and 5th axis not referenced.Pls guide me the way to reference the 4th and 5th axis.When you try to move to zero using machine position putting the values x=0,y=0,z=0, b=0,c=0, folllowing error appears"4th and 5th axis not referenced"
    jolly
    Deisnger shaik inc(arabia)
    Moderator Switcher's Avatar
    Apr 2005
    mydxf.blogspot.com
    I run a 5-axis Schutte grinder that has the "Siemens 840D Control" so I'm not sure I can help, but I'll tell you what I know about the 840D.
    When you first power up the machine, you have to reference out the ( X,Y,Z & C ) axis. The "A-axis" does not need to be referenced out, (on my machine/setup).
    To reference out the ( X,Y,Z & C ) axis, I do this:
    (1) Select " Jog Screen "
    (2) Press the soft key, " Reference All ".
    (3) Press the " X " Button on the Control Panel.
    (4) Press the " + " Button on the Control Panel.
    Note:
    Make sure feed dial is turned up, so axis will move. And make sure you select " Reference All ", -----------> NOT " Reference Single" <-----------
    Apr 2005
    mydxf.blogspot.com
    I just noticed, this is in the "Test Forum". Did you really need help?
    Or just testing a post out?
    Nov 2006
    Bahrain
    our control is 840 Di not 840 D only
    Quote Originally Posted by Switcher View Post
    Note:
    thank you swithcher.But our controll does'nt have the option for "reference all" as it is siemens 840 Di not 840 D only.It does not allow you to reference everytime you switch the machine .it is only referenced once when commissioned.
    This is not a test run I really need help.We are really facing problems
    Apr 2005
    mydxf.blogspot.com
    Sorry , I wasn't much help. Maybe another member will be able to answer your ?s.
    Nov 2006
    Bahrain
    We are really trouble regarding the B and C axis reference.I am attaching the schematic image of the machine.Pls see the image attached
    Attached Thumbnails Attached Thumbnails CNC 5-axis VMC with Siemens 840 control-millmaster-5x.jpg   CNC 5-axis VMC with Siemens 840 control-rotary_table.gif   CNC 5-axis VMC with Siemens 840 control-bt_values.gif
    Apr 2005
    mydxf.blogspot.com
    Is this a new machine (Have you ever had it running)?
    Any way to get a better screen shot of the control panel, http://www.cnczone.com/forums/attach...9&d=1162979667
    Also what is the exact error your getting?
    On my 840D, it has a MMC (Help File) that you can find out what needs to be done, to correct the error. Note: some remedies in that MMC are lame at best!
    Do you have the machine manuals?
    Apr 2005
    mydxf.blogspot.com
    Just curious, are you running Windows XP, on that 840Di ?
    Apr 2005
    mydxf.blogspot.com
    jolliesconcept,
    I have a link to the Siemens Forum:
    http://www.automation.siemens.com/WW...nferences.aspx
    And a link to all the manulas in PDF that you should need.
    https://www.automation.siemens.com/d...06_e&scope=all
    I would advise to get the manuals while you can, Siemens has this thing about changing links.
    I think that Forum, should get you up & running.
    Nov 2006
    Bahrain
    Yes it is a new machine.We bought it from a US supplier.
    Nov 2006
    Bahrain
    Yes we are running on XP
  • Posting Permissions
